[A] Przełożenie przekładni głównej
Postprzez jack 2.2 dti » 03 mar 2010 14:30:42
Silnik 2.0 do połowy roku 1995 / ogumienie 225/75 – 4.88:1
Silnik 2.0 do połowy roku 1995 / ogumienie 255/75 – 5.13:1
Silnik 2.4 , ogumienie 225/75 - 4.56:1
Silnik 2.4 , ogumienie 255/75 - 4.88:1
Silnik 2.0 od połowy roku 1995 / ogumienie 255/65 – 5.13:1
Silnik 2.2 , ogumienie 255/65 - 4.88:1
Silnik 2.8 diesel , - 4.56:1
Silnik 2.5 diesel - 4.3:1
Frontera 3 drzwiowa , most przedni – 9 HU 0.9 litra oleju
Frontera 5 drzwiowa, most przedni 1.7 litra oleju
Most tylny - standard 2.3 litra oleju
Most tylny - z LSD 1.9 litra oleju
Dane pochodzą z Niemieckiej Książki "Reparatur anleitung - Opel Frontera A" :wink:
Opel Frontera B sport 2.2 DTI
jack 2.2 dti
Re: Przełożenie przekładni głównej Frontera A
Postprzez brum » 15 wrz 2010 17:40:50
Info o mostach. niestety po angielsku
http://forum.planetisuzoo.com/viewtopic ... ec7a559f9b
http://forum.planetisuzoo.com/viewtopic ... 13d337c28c
Just thought I let you guys know that the rear axle of a Fronty`A` is a Salisbury 16HA, not 4HA as some people have said in the past, and here`s confirmation about it, no info on front axle though!!
Hi
the axle is a Salisbury 16HA,we have LSD units for the Rear axle,these cost £585.00,there is no LSD unit for the Front axle,im not sure if there after market units made for the Frontera
Later Fronteras use an American Dana axle which looks very similar to a 4HA but it is NOT the same unit & parts from these axles will not change over.i hope this helps,if we can be of service to feel free to ask any more questions
Best Regards
And now a little info on the front axle of a Fronty `A`.
Hi Dave
There are 2 types fitted,the 2 door model has the smaller 9HA,& the 5 door has the 12 HA,axles are also coded for different ratios,just because its the same model does not mean it will have the same ratio
Always check the ratios are the same,there is a 5.1,4.88,4.56 & a 4.3,the 4.3 was at first only for export models,but was used on later models
Best regards
Przełożenia Troopera:
http://4x4fotos.nl/upload/files/bq2n54c ... weayfr.jpg
Czyli: Sport 2.0 ma jeszcze słabszy most niż jakikolwiek Long.
Postprzez jrzeuski » 23 wrz 2010 11:33:30
Spędziłem ładnych parę godzin w sieci szukając informacji o mostach Salisbury. Chodziło mi o serwisówkę do mostów 12HA/16HA, bo takie mam. Znalazłem jedynie serwisówkę do mostów 5HA/7HA, ale za to jaka piękna: szczegółowo opisana budowa i parametry wszystkich odmian oraz montaż z momentami dokręcenia wszystkich śrub. Leży sobie na jednym z ruskich serwerów. Gdyby udało się komuś znaleźć serwisówkę od naszych mostów, to zapodawać tu od razu.
Przy okazji dowiedziałem się, że Salisbury i Dana to mosty de facto tego samego producenta (amerykański Spicer), ale niekompatybilne ze sobą (części nie są zamienne).
Postprzez brum » 07 paź 2010 17:28:54
Gdyby ktoś szukał w Trooperze przełożeń
Trooper '92-'98
3.2 V6 Manual - 4,30
3.2 V6 Automat - 4.555 (opcja - 4,77)
3.1 TDI Manual/Automat - 4.555
Postprzez jrzeuski » 08 paź 2010 08:08:05
brum napisał(a):Trooper '92-'98
No to już wiem skąd wezmę przedni most jak swój zajeżdżę :P
