[A 2.2] X22XE X22SE jaki mam silnik?
Re: jaki mam silnik?
Postprzez DAN » 18 cze 2009 12:44:20
OPEL / VAUXHALL Frontera B 2.2 16V X 22 SE 1999-2000
Za sterownie silnikiem odpowiada "Multec"
Info z Programu Vivid WorkshopData ATI 2008
Frontera 2.2 16V benzyna + Tylny most z LSD + LPG Autronic AL700 - Reduktor Tomasetto 140hp - Opony BRIDGESTONE DULER A/T
DAN
Dołączył(a): 07 mar 2009 16:28:40
Postprzez roozga » 18 cze 2009 14:55:04
Poniżej masz wszystko dotyczące swoje silnika, wraz z momentami dokręcania itd - wszystko co tyczy się twojego silnika. załączył bym w formie bardziej czytelnej ale nie umiem załączyć pdfa na tym forum :)
Vehicle identification
No. of cylinders Type 4/DOHC
Capacity (Fiscal) cc 2198
Compression ratio :1 9,6
Suitable for unleaded petrol Yes
Minimum octane rating RON 95
Ignition system Make Multec
Ignition system Type Multec-S
Ignition system Description Map-DIS
Trigger location Cam/ Crankshaft
Fuel system Make Multec
Fuel System Type Multec-S
Fuel System Description MFI-i
Air metering Type Mass
Combined ignition and fuel ECM Yes
Diagnostic socket Yes
Ignition system
Ignition coil supply voltage + with ballast V 12,0
Firing order 1-3-4-2
Tuning and emissions
Ignition timing - basic BTDC °Engine/rpm Not adjustable
Ignition advance checks °Engine/rpm ECM Controlled
Idle speed rpm 700-1000 Not adjustable
Oil temperature for CO test °C 80
CO level at idle speed - tailpipe Vol. % CO 0,5 Max Not adjustable
HC level at idle speed ppm 100
CO2 level at idle speed Vol. % CO2 14,5-16
O2 level at idle speed Vol. % O2 0,1-0,5
Increased idle speed for CO test rpm 2800-3200
CO content at increased idle speed Vol. % 0,3
Lambda at increased idle λ 0,97-1,03
Spark plugs
Spark plugs Original equipment Bosch
Spark plug Type FLR8LDCU
Electrode gap mm 1,0
Spark plugs Make Bosch
Spark plugs Make Champion
Spark plug Type RC10DMC
Spark plugs Make NGK
Spark plug Type BKR6EK
Electrode gap mm 0,8
Fuel system
Manufacturer: Opel/Vauxhall Model: Frontera-B 2,2
Engine code: X22SE Output: 100 (136) 5200
System pressure bar 3,0
Service checks and adjustments
Valve clearance -INLET mm Hydraulic
Valve clearance -EXHAUST mm Hydraulic
Oil pressure bar/rpm 1,5/850
Radiator cap bar 1,2-1,5
Thermostat opens °C 92
Drive belt size - alternator mm 24x1725
Drive belt size - AC mm 24x2050
Lubricants and capacities
Engine oil grade - cold climate SAE 5W/30
Engine oil grade - moderate climate SAE 15W/40
Engine oil grade - hot climate SAE 20W/40
Engine oil classification API/ACEA SJ/A2-96
Engine oil grade - alternative - moderate climate SAE 10W/40 Semi-synthetic
Engine oil classification - alternative - moderate climate API/ACEA SJ/A3-96
Engine with filter(s) litres 4,7
183 Manual gearbox oil grade SAE 5W/30
35 Manual gearbox 4/5 speed litres
Differential oil grade - front SAE 90W
Differential front/AT litres 1,5
Differential oil grade - rear SAE 90W
Differential rear litres 1,8
Cooling system litres 8,3
Brake fluid Type DOT 4
Brake fluid litres 0,4
Power steering fluid Type Dexron III
Power steering fluid litres 1,0
Tightening torques
Cylinder head instructions
Cylinder head
Renew bolts Yes
Stage 1 Tighten 25 Nm
Stage 2 Tighten 90°
Stage 3 Tighten 90°
Stage 4 Tighten 90°
Other tightening torques
Main bearings Renew bolts/nuts Yes
Main bearings Stage 1 50 Nm
Main bearings Stage 2 45°+15°
Big end bearings Renew bolts/nuts Yes
Big end bearings Stage 1 35 Nm
Big end bearings Stage 2 45°+15°
Oil pump to cylinder block 8 Nm
Sump bolts 8 Nm+30°
Sump drain bolt 55 Nm
46 Flywheel/driveplate
Clutch to flywheel 20 Nm
10 Crankshaft pulley/damper centre bolt
69 Camshaft sprocket/gear
Camshaft carrier/cap 8 Nm
Camshaft/rocker cover 8 Nm
Inlet manifold to cylinder head 22 Nm
Exhaust manifold to cylinder head 22 Nm
Spark plugs 25 Nm
Lambda sensor (Oxygen) 30 Nm
Knock sensor (KS) 20 Nm
Steering wheel 34 Nm
Steering track rod end 118 Nm
Brake disc to hub Front 103 Nm
Brake caliper to carrier Front 74 Nm
Brake caliper carrier to hub Front 155 Nm
Brake caliper to carrier Rear 44 Nm
Brake caliper carrier to hub Rear 155 Nm
Back plate to hub Rear 13 Nm
ABS sensor Front 8 Nm
ABS sensor Rear 11 Nm
Road wheels 120 Nm
Starting and charging
Battery V/RC(Ah) 12/110 (62)
Maximum cranking amps A 167-205
Alternator output at engine speed A/V/rpm 100/14/3000
Brake disc and drum dimensions
Minimum disc thickness - ventilated Front 24,6 mm
Minimum disc thickness Rear 16,6 mm
Disc thickness variation Front 0,010 mm
Disc thickness variation Rear 0,010 mm
Disc runout Front 0,13 mm
Disc runout Rear 0,13 mm
Maximum drum diameter Rear 211,4 mm
Minimum pad thickness Front 1 mm
Minimum pad thickness Rear 1 mm
Parking brake travel No. of notches 6-8
Air conditioning
Air conditioning refrigerant Type R134a
Air conditioning refrigerant quantity grams 650
Air conditioning oil Type PAG
Air conditioning oil quantity cmł 270
Autodata Note 183
Gearbox oil grade
Vehicles consistently operating below 32°C = 5W/30
Vehicles consistently operating above 32°C = 40 or 50
Autodata Note 35
Gearbox capacity
Gearbox = 3,0 litres
Transfer box = 1,5 litres.
Flywheel/drive plate
Use new bolts and tighten to 65 Nm + 30° + 15°.
Tighten drive plate to 60 Nm.
Autodata Note 10
Crankshaft pulley
Use new bolts. Tighten centre bolt to 130 Nm + 40°-50°.
Camshaft sprocket
Use new bolts and tighten in the following stages:
1) 50 Nm
2) 60°
3) 15°.
Cylinder layout Tightening sequence
roozga
Postprzez gabrielll1 » 19 cze 2009 15:20:40
:) OK Dzięki
gabrielll1
Postprzez nightman » 19 cze 2009 15:43:03
gabrielll1 napisał(a):...Szukałem Scenika a przyjechałem Fronterą do domu...
i właśnie takie wybory sie chwali :)
nightman
Powrót do 2.2i
